ferben
Aug 27, 2015Follower
WNDR3700v5 Apple TimeMachine support
Hello, acording to official user's manual for WNDR3700v5 (http://www.downloads.netgear.com/files/GDC/WNDR3700V5/WNDR3700v5_UM_12Jan2015.pdf – page 65) is possible use this router for backing up via...
- Aug 31, 2015
Hi ferben,
Welcome to the community!I apologize but the Time Machine is not and will never be supported on WNDR3700v5. Netgear is currently working on the documentation posted on the site. I suggest that you get WNDR4300v2 instead. Again, I apologize for the inconvenience this has caused you.
ElaineM
Aug 31, 2015NETGEAR Employee Retired
Hi ferben,
