Baxter27's avatar
Baxter27
wndr3800 802.11 issues streaming vudu
Am having trouble with connecting to vudu while watching a movie
  • ElaineM's avatar
    ElaineM
    Apr 04, 2016
    Hi baxter Can you further describe more? How do you stream vudu? is this through an app or you're using a vudu stick?
    Are there any device or connections affected aside from vudu?
    Do you stream it wired or wireless connection?
