sAINTfRESH
Oct 26, 2022Aspirant
WNDR3800 only getting 300Mbps with hard wired connection.
Hello Netgear Community! Hope everyone is doing well. So a buddy of mine was getting rid of some things he didn't need anymore and I snagged the Netgear N600 Wireless Dual Band Gigabit Router -Pr...
Oct 26, 2022Guru - Experienced User
Or that age of router and its design, it's probably hitting the max speed. NOt sure of that model router supported or had any Cut thru or HW NAT accelleration support which is needed for high speeds near 900Mpbs over a ethernet connection.
- sAINTfRESHOct 26, 2022Aspirant
is that kind of like what power over ethernet does? the N600 is just a normal 12v switching power supply and the Unifi ap is PoE switching gigabit power supply.
- FURRYe38Oct 26, 2022Guru - Experienced User
No.
