Grizz29
Aug 31, 2022Follower
WNDR4000 — N750 Wireless Dual Band Gigabit Router
I just bought a security camera that requires 2 ghz and my router is currently using 5 ghz. How do I add another network so I can add my camera? It is a dual band router.
Sep 01, 2022Guru - Experienced User
the wndr4000 has both 2.4ghz and 5ghz.
Try logging into the router and check to see if the 2.4ghz is enabled or what the ssid for it is.
Also, is the 2.4ghz led on the router lit up? or is it off
