RBusiness
Sep 03, 2015Aspirant
WNDR4000 LOGIN ISSUE
I have had our WNDR4000 in operation inhouse on a small LAN with about 15 devices connected, has been trouble free for q couple years until I added an Access Point yesterday and now can not log in to...
RBusiness
I just tried to connect to the router 192.168.1.1 and after getting the same not able to connect message, I did the Windows Network Troubleshooting and the problem it found says
"Problem Found
The remote device or resource won't accept the connection"
ElaineM
Sep 10, 2015NETGEAR Employee Retired
- RBusinessSep 10, 2015Aspirant
Thank You for replying to my question. I had been remotely connected to a couple accounts and was afraid that if I disconnected from to reset the router I would not be able to get the router to come back up immidiately so wated till I finished and then disconnected and restarted the Router and was then able to communicate with no problem.
So this issue is RESOLVED
