Sharky81
May 12, 2016Novice
WNDR4000 N750 VDSL Support
Hello, I´m from German and want change my internetprovider. I have a WNDR4000 WIFI router. And my question is, supports my router annex-j and the standard 1TR112 protocol for using VDSL from Tel...
ElaineM
May 16, 2016NETGEAR Employee Retired
Hello Sharky81
Welcome to the community!
Our routers will work with your modem as long as it support the protocols you mentioned.
Now, if you decided to get one of our VDSL gateways all mentioned protocols are supported.
Should you need to check our VDSL gateways see here.
