Zap3174
Oct 13, 2021Tutor
WNDR4000 Speed Issues
I upgraded my internet service with my ISP because we needed our internet faster since I started working from home. However, we saw no difference in download speed when conducting speed tests. My ISP...
Oct 13, 2021Guru - Experienced User
What speeds are you getting?
it might be indeed time to upgrade as thats an 8 year old device and a couple generations behind on technologies.
- michaelkenwardOct 14, 2021Guru - Experienced User
plemans wrote:
it might be indeed time to upgrade as thats an 8 year old deviceThe original manual says 2010.
Coming up for its 12th year!
- Zap3174Oct 14, 2021Tutor
Here are a few download speeds for my devices: 50-75 Mbps on my personal XPS13. Around 20-40 Mbps on my Nintendo Switch. And around 30-50Mbps on my Iphone XR. Upload speeds for all seem consistent at around 20 Mbps.
And yeah the router is quite old. Just wanted to make sure there was nothing left to do to solve the issue before fully replacing it.
- plemansOct 14, 2021Guru - Experienced User
Seems to be right around where it was tested at depending if you're on 2.4ghz/5ghz and how many antennas your devices is using. Its has a 3x3 antenna array for 5ghz but most devices only have 1x1 or 2x2 antenna's internally.
I'd be looking at upgrading
Gotcha, thanks for the info!
