purplesky2
Sep 12, 2015Tutor
WNDR4300 5ghz
How can I turn my 5ghz band on for my wndr 4300 router?
- Sep 17, 2015Try using channel 149. The upper channels are allowed to broadcast at higher power.
Check the driver settings for the tplink and make sure the 5 GHz band is enabled.
Run a Wi-Fi surveyor program, like inSSIDer, vistumbler, or Acrylic Wi-Fi. It will report what networks it can see.
Make sure the antennas on both the router and tplink card are properly installed.
ElaineM
Sep 14, 2015NETGEAR Employee Retired
Hi purplesky2,
Welcome to the community!
The 5Ghz signal should be on by default.
For some reasons that it's not broadcasting, you may want to check the settings by accessing the admin page of the router. Look if SSID broadcast is enabled.
See page 29 from this link.
Let us know what happens.
purplesky2
Sep 14, 2015Tutor
that didnt work, even tried to manually add the connection
