purplesky2
Sep 12, 2015Tutor
WNDR4300 5ghz
How can I turn my 5ghz band on for my wndr 4300 router?
- Sep 17, 2015Try using channel 149. The upper channels are allowed to broadcast at higher power.
Check the driver settings for the tplink and make sure the 5 GHz band is enabled.
Run a Wi-Fi surveyor program, like inSSIDer, vistumbler, or Acrylic Wi-Fi. It will report what networks it can see.
Make sure the antennas on both the router and tplink card are properly installed.
purplesky2
Sep 14, 2015Tutor
that didnt work, even tried to manually add the connection
ElaineM
Sep 15, 2015NETGEAR Employee Retired
purplesky2 Do you still have the 5Ghz LED light on the front panel of the router? Can you still see the name that it broadcast? How about the 2.4Ghz signal can you see its broadcasted signal?
Have you tried resetting and reconfiguring the router?
Looking forward to your response.
