purplesky2
Sep 12, 2015Tutor
WNDR4300 5ghz
How can I turn my 5ghz band on for my wndr 4300 router?
- Sep 17, 2015Try using channel 149. The upper channels are allowed to broadcast at higher power.
Check the driver settings for the tplink and make sure the 5 GHz band is enabled.
Run a Wi-Fi surveyor program, like inSSIDer, vistumbler, or Acrylic Wi-Fi. It will report what networks it can see.
Make sure the antennas on both the router and tplink card are properly installed.
purplesky2
Sep 16, 2015Tutor
I think its that my wifi adapter cant pick up 5 ghz signal, got a wireless card that can, will update after install
- purplesky2Sep 16, 2015Tutor
update: wireless card installed, still cant connect to the 5 ghz channel
its enabling the 5g band, but im not picking it up with wireless card
