purplesky2
Sep 12, 2015Tutor
WNDR4300 5ghz
How can I turn my 5ghz band on for my wndr 4300 router?
- Sep 17, 2015Try using channel 149. The upper channels are allowed to broadcast at higher power.
Check the driver settings for the tplink and make sure the 5 GHz band is enabled.
Run a Wi-Fi surveyor program, like inSSIDer, vistumbler, or Acrylic Wi-Fi. It will report what networks it can see.
Make sure the antennas on both the router and tplink card are properly installed.
TheEther
Sep 17, 2015Guru
Go to Advanced > Advanced Setup > Wireless Settings and make sure Enable Wireless Router Radio is set for the 5 GHz network's
What is the model of your wireless card?
- purplesky2Sep 17, 2015Tutor
everything is turned on, and i have a tplink wireless card
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704133
- ElaineMSep 17, 2015NETGEAR Employee Retired
purplesky2 Can you see other wireless networks in your area? Do you have another device that can see the signal of the router such as a laptop, phones, tablets?
