purplesky2
Sep 12, 2015Tutor
WNDR4300 5ghz
How can I turn my 5ghz band on for my wndr 4300 router?
- Sep 17, 2015Try using channel 149. The upper channels are allowed to broadcast at higher power.
Check the driver settings for the tplink and make sure the 5 GHz band is enabled.
Run a Wi-Fi surveyor program, like inSSIDer, vistumbler, or Acrylic Wi-Fi. It will report what networks it can see.
Make sure the antennas on both the router and tplink card are properly installed.
purplesky2
Sep 17, 2015Tutor
everything is turned on, and i have a tplink wireless card
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704133
ElaineM
Sep 17, 2015NETGEAR Employee Retired
purplesky2 Can you see other wireless networks in your area? Do you have another device that can see the signal of the router such as a laptop, phones, tablets?
