purplesky2
Sep 12, 2015Tutor
WNDR4300 5ghz
How can I turn my 5ghz band on for my wndr 4300 router?
- Sep 17, 2015Try using channel 149. The upper channels are allowed to broadcast at higher power.
Check the driver settings for the tplink and make sure the 5 GHz band is enabled.
Run a Wi-Fi surveyor program, like inSSIDer, vistumbler, or Acrylic Wi-Fi. It will report what networks it can see.
Make sure the antennas on both the router and tplink card are properly installed.
TheEther
Sep 17, 2015Guru
purplesky2
Sep 17, 2015Tutor
changing the channel to 149 worked out, instantly saw the 5 ghz band Thak you both for all the help :)
