psky
Jan 18, 2017Aspirant
WNDR4300 Connection is not private, certificate authority invalid
When we try to connect to the internet with our cells, tablet, laptop, we get; "Your connection is not private", NET::ERR_CERT_AUTHORITY_INVALID. Called my internet provider who troubleshooted o...
- Jan 21, 2017Factory reset worked! You saved me from having to buy a new router, thanks.
ElaineM
Jan 19, 2017NETGEAR Employee Retired
Welcome to the community, psky
Did you try using a different browser?
Which browser are you using?
Have you also tried doing a factory reset on the router?
After resetting the router, reconfigure it as if it's brand new out of the box then check for your connection.
