wnuczus
Feb 27, 2017Aspirant
WNDR4300 don't see extend hdd
Hi, i cant use my extend hdd because dlna dont see it on the settings usb i see my hdd In ready share no. What i doing wrong?
- Mar 04, 2017
I found solution. Probem was with EFI I had to delete EFI from hdd and change boot to MBR. Now works perfectly
ElaineM
Mar 02, 2017NETGEAR Employee Retired
You may need to reformat that hard drive if you want to use it with the router.
wnuczus
Mar 04, 2017Aspirant
- aalexandrebetaMar 04, 2017Master
wnuczus glad to see you solved your issue.
ElaineM that is why NG should "put on the front door" the recommendations and make things clear once an for all.
