ebgreene_89's avatar
ebgreene_89
wndr4300 firmware update not working
I received an email from NETGEAR regarding an update to my WNDR4300 firmware. As it was uploading I got this message, and could go no further: "Secure Connection Failed An error occurred during a...
  • DexterJB's avatar
    Mar 24, 2019
    Hi ebgreene_89,
    You can try using another browser or device and see if the issue will persist. Also, make sure that the time setting on the device your using to upload the firmware is correct (same with the router).
    Dexter
