LexLuthor's avatar
LexLuthor
wndr4300 ftp help
Ok, this might be of some old work.     Here is the situation, I have this router and a usb attached to it.  I can see that the usb is connected to the router throught the main menu.  I also see th...
  • LexLuthor's avatar
    LexLuthor
    Aug 25, 2017
    II have  checked the port under port forward/triggering for port 21 and it is set.
    i have this router set as a main ap before it goes through a cable modem and to the ISP.  I cannot set the port for some weird reasons under ready share and I cannot see the port through an INTRANET option like computer to computer using a program like cerebus or a ftp server.
    When i I try to select this option under the ready share within the router, it tells me that the port is being used and needs to be checked.  I then went through and made sure that the port was not being used as a service on the router and I get the same error.  I re establish a new ftp service and open the port, I get the same error.  I'm totally lost.
