DryHeat97
Jul 01, 2018Aspirant
WNDR4300 How do I know what network to connect to? Netgear34 or Netgear34-5g?
Hello, please forgive me if I don't understand technical talk. I am technical enough to understand layman terms and not a complete beginner in understanding the basics of my router. A couple question...
- Jul 02, 2018
5G = 5 GHz wifi. The other one is 2.4 GHz.
DryHeat97 wrote:
Can I rename both my Netgear34 and my Netgear34-5g the same name?
Yes.
There is a manual for the WNDR4300 somewhere at the end of this link:
>>> WNDR4300 | Product | Support | NETGEAR <<<
Start at page 29. You need to change the SSIDs. And you could give them passwords that are easier to remember!
michaelkenward
Jul 02, 2018Guru - Experienced User
Yes.
DryHeat97
Jul 02, 2018Aspirant
Thank you. I tried it again and it worked this time.
