Lord_A
Jan 12, 2022Initiate
WNDR4300 Maximum number of wired connections
 TL;DR: Is there a limit to how many devices can connect to the WNDR4300 through a single ethernet port? And if so, what is that limit?     Okay , I know I have kind of a wierd setup, but still, I can...
Jan 12, 2022Guru - Experienced User
Easy test?
For the time being, take the WNDR4300 out of the equation.
Direct connect the random mesh system and see if it can tolerate all the wired/wireless connections.
If it has issues/problems, you know that's where the problem is stemming from.
If its rock solid/stable, then its either the wndr4300 or how you have everything setup.
- Lord_AJan 13, 2022InitiateSimple. Logic. Sometimes obvious just stares you in the face for so long, that you don't see it :-D Thanks, will try.
