jimmyo68
Aug 23, 2015Aspirant
WNDR4300 ReadyShare issue after firmware Upgrade to 1.02.80
I'm having a weird issue after upgrading my Netgear WNDR4300 to 1.02.80 from 1.01.60 firmware level. I have a Western Digital 500GB MyBook that has worked for years without issue. It is connected t...
- Sep 06, 2015
ElaineM,
The problem is now resolved. I performed the following steps:
1. Attached the WD MyBook 500GB USB drive to my laptop.
2. Ran the Windows 10 scandisk tool which indicated it repaired errors.
3. Due to results in #2, I decided to copy the USB contents to a temp directory on my laptop.
4. I was able to copy all but a few files to the temp directory.
5. Used a sync tool to confirm I had all folders/files in the temp directory from the USB drive.
6. Ran Windows 10 format against the USB drive as NTFS (did not use quick format option).
7. Moved folders/files back to USB drive.
8. Went into Windows 10 security tab for USB drive and made sure all users had ful authority to USB drive.
9. Connected USB drive back to router USB port.
10.Went into advanced settings and added the WD MyBook USB drive to readyshare.
Everything is back to normal. Not sure if I can blame this on the firmware upgrade. I was able to add folders/files to the drive a couple of months before the firmware upgrade.
Jim
jimmyo68
Update -
I see the following entries in the router log:
[WLAN access rejected: incorrect security] from MAC address xx:xx:xx:xx:xx:xx, Sunday, August xx, 2015 13:46:01
I see this error in the log when the USB drive is connected to ReadyShare and i am accessing directories from my Windows 10 Pro laptop. Any ideas on the cause of this message?
Jim
- jimmyo68Aug 29, 2015Aspirant
WLAN access reject error resolved. Had a mac address issue with one device that was reset.
