brian_j's avatar
brian_j
wndr4300 READYSHARE
Having trouble setting up usb drive on my whdr4300 router ... Under Create Network Folder, it lists my USB drive, But "Browse" button for folder does not display any of the directories on the drive...
  • brian_j's avatar
    brian_j
    Jan 30, 2016
    Added several thousand media files and everything seemed fine.  Was listening to audio tracks. Half an hour later, the server started going was up and down.
    It came backup, but many of my media files were not available.
    I tried to rescan the media files and it didn't do anything.  I tried deleting the contents in the .ReadDLNA file, but it would not let me rebuild.  The log said something about the art cache ( appeared to be an error, I don't recall ).
    I had to repair the drive, then completely delete the .ReadyDLNA directory, then the scan started to work ( according the the minidlna.log ).
    Lesson: Delete the entire .ReadyDLNA directory ( including the directory ) to force a media rescan.
    So far, the ReadyDLNA, ReadyShare, and ReadyNasRemote is working as it should.
