K0RC
Aug 21, 2015Aspirant
WNDR4300 shows two WiFi networks available on Win 8.1 and Win 10 but not Win 7
I recently installed a couple of NetGear N750 routers (at different sites) and they are working as expected (almost). I am puzzled why I see two WiFi network "signals" when viewing "Available WiFi co...
- Aug 31, 2015
Thanks for looking for an answer . . . There really isn't much to see regarding a screen shot. When I would click on the WiFi icon in the bottom tray I would see two "WiFi"s available. The first was K0RC-2G and it said connected. The second was K0RC-2G 2 and it was not connected.
As mentioned before I drilled my way down into the "Preferred WiFi Networks" menu (where the list of every WiFi you have ever connected to will appear) and it ( the "2") was listed there. I simply deleted it and that seems to be the solution. The very odd aspect is that I have three computers on WiFi in this location. One is Win 7, one is Win 8.1, and a Win 10. The Win 7 did not capture the phantom "2" WiFi but both Win 8.1 and Win 10 did.
In any case, problem solved. The "2" network has not reappeared on either Win 8.1 or Win 10 since then, through many reboots and reconnects.
Thanks for your attention to this issue.
I am writing this off as a fluke.
ElaineM
Aug 31, 2015NETGEAR Employee Retired
K0RC Tried inquiring this to engineering and it seems that they are unable to replicate this and doesn't have any idea too how and why it happened. If it happens again, please post a screenshot.
K0RC
Aug 31, 2015Aspirant
