Ronnies
Apr 17, 2017Aspirant
WNDR4300 Slow Wired Speed
My ISP recently upgraded me from 300mbs internet to 4000mbs internet. Previously on a speed test I would get upwards of 320, now I'm seeing 150-180 at best. When I wired my PC directly to my mod...
- Apr 18, 2017
30-30-30 did not fix the issue, still experiencing slow speeds.
I'll look into an RMA but I suspect I'm outside of the warranty window.
Thanks for the suggestion.
ElaineM
Apr 18, 2017NETGEAR Employee Retired
Welcome to the community, Ronnies
It's true that the router should be able to handle up to 1Gbps of Internet connection.
I suggest that you try a hard reset.
1. With the unit powered on, press and hold the reset button on the back of unit for 30seconds.
2. Without releasing the reset button, unplug the unit and hold reset for another 30 seconds.
3. Power on the unit while STILL pushing the reset button and count for another 30 seconds before letting it go.
If you're still getting the same speed, it must be a hardware issue.
I suggest that you get an RMA if it's within warranty.
Ronnies
Apr 18, 2017Aspirant
