jjmediaman
Sep 02, 2015Aspirant
WNDR4300 Upstream Qos killing internet speed
WNDR4300 - Discovered that I was only getting 9Mbps downstream. Disabled Upstream QOS and it shot up to 50 Mbps. Is there a solution for this other than leaving it disabled? Is there a firmware or ot...
- Sep 03, 2015
Hi jjmediaman,
Welcome to the community!
Did you set some QoS rule? What was set on your Uplink Bandwidth? Have you tried setting a different value under the uplink bandwidth?
Try around 85% of your uplink bandwidth and see if it will make any difference.
Looking forward to your response.
ElaineM
Sep 03, 2015NETGEAR Employee Retired
Hi jjmediaman,
jjmediaman
Sep 10, 2015Aspirant
I turned it off. Gaming seems to not be affected.
- ElaineMSep 10, 2015NETGEAR Employee Retired
