az6351
Apr 10, 2017Aspirant
WNDR4300 v2 Slow speed
Hi, I recently ran into an issue that my WNDR4300 v2 router has slow speed, especially for wired connection. For instance, online video stream start constant buffering 1-2 mins after opening; BT down...
ElaineM
Apr 11, 2017NETGEAR Employee Retired
Welcome to the community, az6351
Did you try to factory reset the router?
It might be possible that the router is slowly degrading.
Have you also tried using all LAN ports available? Is it the same result for all?
