az6351's avatar
az6351
WNDR4300 v2 Slow speed
Hi, I recently ran into an issue that my WNDR4300 v2 router has slow speed, especially for wired connection. For instance, online video stream start constant buffering 1-2 mins after opening; BT down...
  • ElaineM's avatar
    ElaineM
    Apr 12, 2017
    I suggest that you contact support and get an RMA since it's not normal for the speed to drop.
