Madhatter1983
May 06, 2021Aspirant
WNDR4300v2 100mbps, internet speed is 400mbps hardwired
everytime a do an internet speedtest i get 100mbps through my WNDR4300v2, if i switch my pc to hardwire off my modem i get 40mbps. Can anyone help me max my speed? the router is rated for 450mbps.
May 07, 2021Guru - Experienced User
Are you testing hardwired into the router or over wireless?
What firmware is on the router?
What do you port statistics show for the connected device you're testing on?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
