ExpandtheMind
Apr 03, 2018Aspirant
WNDR4300v2 NetGear Genie App Name Issue
Hello all, Simply reaching out to kindly ask how one changes the name associated with their Netgear Genie app. To be clear, when one opens the app and presses the three horizontal lines in t...
- Apr 12, 2018
Hi ExpandtheMind,
1. When logging in for the Remote Login feature, do the credentials that you have setup (username and password) still work as expected?
2. If you prefer, you can always reset the router to factory defaults and go through the setup of the Remote Login feature. You may find the links below helpful:
Reset: link
Remote Login: link
3. Also, if you feel uncomfortable, you can change the passwords associated to the feature (email, MyNETGEAR account, Remote Login).
Dexter
Community Team
DexterJB
Apr 12, 2018NETGEAR Moderator
Hi ExpandtheMind,
Reset: link
Remote Login: link
Dexter
Community Team
DexterJB
Apr 15, 2018NETGEAR Moderator
Hi ExpandtheMind,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
