carlos1984's avatar
carlos1984
Follower
Jun 29, 2017
WNDR4300V2 REMOTE ACCESS
I am trying to remote access  my router using this
https://kb.netgear.com/26109/How-to-remotely-access-your-router-using-NETGEAR-Desktop-genie#
I have installed genie on my remote deskto and local, and on both I cannot see the remote access dropdown on the login page.
Any help?
  • Welcome to the community, carlos1984
    The router is not supported for remote access.
    You will need a newer hardware for that.
1 Reply
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
