J12
Jan 03, 2017Aspirant
WNDR4300v2 Signin & Wifi Inop
Came back after weekend and wifi is inop. rebooted, ... stil inop. I am also now unable to login to see any settings. Please advise
- Jan 04, 2017
I used a pin to restore the router to original manufacturer settings and reentered everything all over again.
Everything works fine now-duh! I'm just over the unprofessional world of PC programming that requires a CTRL-ALT-DEL and/or system restore to routinely solve the basics that should never even happen.
This is what I was hoping to prevent.
Jan 04, 2017Guru - Experienced User
You might need to try a reset.
