J12
Jan 03, 2017Aspirant
WNDR4300v2 Signin & Wifi Inop
 Came back after weekend and wifi is inop.  rebooted, ... stil inop.  I am also now unable to login to see any settings.  Please advise
- Jan 04, 2017I used a pin to restore the router to original manufacturer settings and reentered everything all over again. Everything works fine now-duh! I'm just over the unprofessional world of PC programming that requires a CTRL-ALT-DEL and/or system restore to routinely solve the basics that should never even happen. This is what I was hoping to prevent.
Jan 04, 2017Guru - Experienced User
You might need to try a reset.
J12
Jan 04, 2017Aspirant
