dadcyber
Jun 26, 2016Aspirant
WNDR4500 and Cisco Service blocked: ICMP_echo_req
In my home have i a WNDR4500 and to the wan outside a Cisco from te provider ziggo in the netherlands. The Cisco is programming as 1 ip adres to the netgear but i have programming to 1 to 100 ip. I...
- Jun 27, 2016
Thanks for your welcome.
By the wan side the ping is of "Respond to Ping on Internet Port.
By the Ziggo modem in the firewall choice the
SPI Firewall Protection was medium en now low.
The problem is over.
Thanks for your reply
greetings Dadcyber
ElaineM
Jun 27, 2016NETGEAR Employee Retired
Hello dadcyber
Welcome to the community!
Is "Respond to Ping on Internet Port" unchecked? You should be able to see this option under the WAN setup in the admin page of the NETGEAR router.
dadcyber
Jun 27, 2016Aspirant
The problem is over. |
greetings Dadcyber
- ElaineMJun 27, 2016NETGEAR Employee Retired
You're welcome.
Thank you for your update.
Have a great day!
