chocka
Aug 19, 2016Aspirant
[WNDR4500] Can't reach router by IP (WFAdevice)
I just tried to get into the router by IP 192.168.1.1, but get the error it isn't connecting?
With my mobile and Fing app, I see the router as a WFAdevice???
I didn't change anything with the router, so I don't understand what changed and how to get back into the router?
Just rebooted the router and everything is fine now
- chockaAspirant
PC is wired connected
ping 192.168.1.1 isn't any problem
But as I http://www.routerlogin.net/ do, I get a page "cannot make a connection"
Also tried wireless with my LG, but the same problem "cannot make a connection"
- ElaineMNETGEAR Employee Retired
Try to use another computer or use a different web browser.
You may also try to clear all the browser settings.
If you're saying that you can ping it without any problems then the router should be accessible through its IP address or www.routerlogin.net.
