BORIS48's avatar
BORIS48
WNDR4500 connect TV
WNDR 4500 V1.0.1.46_1.0.76
Hi, firends!
Help with a problem.
I have houses local network:
Connection:
1) The router is connected to TV on Ethernet, the laptop (windows10) to TV on WIfi. The network works. In the folder the network on windows 10 is displayed connected by TV. Between the laptop and TV there is DLNA communication.
2) A router  is connected to TV on Wifi, the laptop (windows10) to TV on WIfi. The network doesn't work. In the folder network on windows 10
it isn't displayed connected by TV. Between the laptop and TV there is no DLNA of communication.
In what problem?
On a tab Local network DHCP I have fixed IP MAC of the address TV of connections on Ethernet and Wifi in a router.
  • The problem is solved today. It was necessary to pull out RG-45 from the TV :)
    Thanks, subject it is closed.
  • I apologize for my bad English, I write through the online translator. Also I will try as it is possible to formulate more clear a question if it is written unclear.
    Yours faithfully, Boris.
    • BORIS48's avatar
      BORIS48
