Tinge1tange1
Jan 01, 2023Aspirant
WNDR4500 denies Samsung A33 to access
Hi all! I'm having trouble with my WNDR4500 router and a Samsung A33 phone that the router keeps blocking. The router is set to block all new devices. When I check, I'll find the A33 device/MAC-ad...
Tinge1tange1
Thanks for your response.
Yeah, it's an antique, but so far I have had no problem with it when addning modern gadgets. 🙂
I've looked in the logs but nothing there stands out as a possible reason.
If I clear the toggle,he phone has no problem to get access to the network. There are some other strange things that I can see in the router.
I tried to give the device a fixed IP-address tied to that specific MAC-address. But even if I have this, the router still assigns a different IP to the same MAC-address when connecting.
The phone has two MAC-addresses as far as I can tell. The hardware MAC; "the phone's wi-fi" and a random MAC changing every 24h. I'm not sure if the router can hadle this? On the other hand, a new iphone 13 which also uses random MAC can connect. Might it be an Android problem?
Also, I'm thinking about WPA2/WPA3 compability. Can this cause something..?
Jan 02, 2023Guru - Experienced User
Some of the newer phones are using random mac/ip addresses to connect with. It causes issues with these types of setups. Sometimes you can disable it on the phone. Have you checked on your phone?
