Johnmitchell9
Jul 04, 2021Aspirant
WNDR4500 N900
Hi new to this, l have got myself a N900 WNDR4500 router and have connected to the Internet lve got WiFi but no Internet and no Internet light but when I connected through my sky broadband hub the Int...
michaelkenward
Jul 05, 2021Guru - Experienced User
Johnmitchell9 wrote:
Hi new to this, l have got myself a N900 WNDR4500 router ....
That is an old (2013) router.
when I connected through my sky broadband hub the Internet light goes orange and l still can use WiFi
What do you hope to do with the WNDR4500? Sky usually supplies a device that also acts as a router. (The exact nature of its boxes depends on the sort of Internet you get.)
Two routers on your network can cause headaches. This explains some of the drawbacks.
What is Double NAT? | Answer | NETGEAR Support
If you just want the WNDR4500 to extend your wifi, then look into putting it into "AP mode".
This does disable some features, but nothing that is likely to matter much given your Sky box.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual that describes AP Mode. If you can't leave the WNDR4500 plugged into the Sky thingy, you could also look at the bit in Wireless Repeating Function (WDS).
Johnmitchell9
Jul 05, 2021Aspirant
Hi thank you for your reply this has made a lot of sence and l now know what l need once again thank you
- michaelkenwardJul 05, 2021Guru - Experienced User
Good luck.
You might get more sense out of people if you described what you were trying to do, and the details of your local network.
