thomas9706
Jan 27, 2017Aspirant
WNDR4500 Ports won't open
Hi, I am trying to host a Minecraft server via portforwarding, but the router won't let me. I can join the server with my internal IP (IPv4) address, but not via the public IP. I've opened the 25...
- Jan 27, 2017
thomas9706 wrote:
There is a modem between the ISP and the router, is it possible that the modem is blocking the port?
If the modem is actually a gateway, then it is blocking the port. What is the manufacturer and model number?
Jan 27, 2017Guru - Experienced User
What is between the router and the ISP? Is it possible that there is a gateway in front of the router instead of a modem?
- thomas9706Jan 27, 2017Aspirant
- StephenBJan 27, 2017Guru - Experienced User
The modem is a Cisco EPC3928.
