MattSnap
Nov 30, 2018Aspirant
WNDR4500 Power Light Blinking
Hi community.
I have a WNDR4500 N900 Dual Band Gigabit Router.
Power light is on and green but blinking which according to the manual suggests corrupt firmware or a firmware update whch was inter...
- Nov 30, 2018
> [...] Power light is on and green but blinking [...]
You may be a candidate for the TFTP recovery scheme. See, for
example:
https://community.netgear.com/t5/x/x/m-p/1622096
antinode
Nov 30, 2018Guru
example:
- MattSnapNov 30, 2018Aspirant
Thank you antinode.
Am just in the process of following the thread and downlaoding the file and TFTP client for my Mac Powerbook.
Fingers crossed.Will update once done.
Many thanks community.
- antinodeNov 30, 2018Guru
> file and TFTP client for my Mac Powerbook. [...]
Keep reading. There should be no reason to download any TFTP client
program; just use the command-line TFTP client which is already on the
Mac:
pro3$ type tftp
tftp is /usr/bin/tftp
> Fingers crossed.
So, marking the thread as "solved" was premature.
Please do.
