boudicca99's avatar
boudicca99
Follower
Oct 24, 2021
wndr4500 warm reboot green power led blinking
interesting failing router. I've already replaced it.... but its an annoying fail, in that it is still working except after a warm reboot or power off/on.
If the router is cold started after about >20mins or so. It boots fine, no loss of settings. completely functional until the next warm reboot or power on/off. and then we get the flashing power light. it even still shows a internet amber and port active too.
PSU have tried 3 different Netgear 12v 3.5amps all from working devices.
Interally no domed caps all look sound, no obvious heat issues. Seems to be warm start ram/firmware issue.
Reflash of the last firmware is next on my hit list.
Any other thoughts than its toast. ?
Cheers
Shaz
1 Reply
  • plemans's avatar
    thoughts or other things to try?
    Stick a cooling/laptop fan on it.
    Heat is the death of electronics and it tends to escalate. Once a component starts over heating it escalates as it becomes less efficient and therefore using more energy/generating more heat.
    You can try a cooler and see if it helps.
    Or you can simply replace it.
    The WNDR4500 is a couple generations behind on tech
