mystic1287
Jan 21, 2017Aspirant
Wndr4500v2- New firmware causing performance issues?
So, I applied the latest firwware update- V1.0.0.62_1.0.39 2 days ago and now my router is performing poorly. On a hard line it takes 20-30 secs to load the admin page. Has anyone else experienced th...
- Jan 22, 2017
Did you perform a factory reset after applying the new firmware?
That is the first thing to try if you have "post-flash" problems.
michaelkenward
Jan 22, 2017Guru - Experienced User
mystic1287
Jan 22, 2017Aspirant
No, but I did re-apply the FW upgrade, back to SNAFU.....rocking!
- michaelkenwardJan 22, 2017Guru - Experienced User
Well done.
Reset isn't always needed, but it is worth trying if something seems wonky.
