Retired_Member
Sep 06, 2016WNDR4500v2 cannot upgrade firmware
When I log into the administration page for the router (WNDR4500v2) it notisfies me with the message: "A router firmware upgrade is available". If I click at the message a new page apears with the t...
- Retired_MemberOct 14, 2016
Hi ElaineM
Thanks for your help. I did a factory reset and after that I was able to update. Must have been a bug in the Netgear software (or the router has been hacked and the netgear software modified to disable updates).
Best regards
Teela.
ElaineM
Sep 07, 2016NETGEAR Employee Retired
Hi Retired_Member
Welcome to the community!
Make sure that it's the correct hardware version.
If it is try to factory reset the router then do it again.
Mine worked properly when I did the auto update through the admin page and also by doing the manual upgrade.
Hi ElaineM
Best regards
Teela.
- ElaineMOct 17, 2016NETGEAR Employee Retired
There might have been a glitched in the software that's why after reset it worked.
Thank you for the update!
