Anonymous's avatar
Anonymous
Sep 06, 2016
WNDR4500v2 cannot upgrade firmware
When I log into the administration page for the router (WNDR4500v2) it notisfies me with the message: "A router firmware upgrade is available". If I click at the message a new page apears with the t...
  • Anonymous's avatar
    Anonymous
    Oct 14, 2016
    Hi ElaineM
    Thanks for your help. I did a factory reset and after that I was able to update. Must have been a bug in the Netgear software (or the router has been hacked and the netgear software modified to disable updates).
    Best regards
    Teela.
