frankc1
Jun 05, 2016Aspirant
wndr4500v2 dropping comcast connection
i have motorola sb6141 cable modem. when pc is directly connected to the cable modem comcast functions well. when i connect to the internet thru my wndr4500v2 router with ipv6 set to WAN/dhcp LAN//...
- Jun 10, 2016
Hi ElaineM,
I have found a solution to this problem. My firewall (Bitdefender) has a default setting to deny incoming ICMP v6 messages. Setting this to allow made the problem vanish.
What I do not understand is why direct connecting the PC to the cable modem worked OK as Bitdefender was still in the loop. Magic I guess.
I believe allowing ICMP messages poses a security risk which seems to be an IPV6 risk. Do you have a comment on this?
Thanks again :-)
ElaineM
Jun 06, 2016NETGEAR Employee Retired
Hi frankc1
Welcome to the community!
Do you have the latest firmware installed on your router?
If you have not upgraded the firmware yet, here's the link.
After the firmware upgrade, kindly factory reset the router by pushing the reset button for 10 seconds with a use of a paperclip.
Once done, reconfigure the router to get the internet connection back and observe your connection.
- frankc1Jun 06, 2016Aspirant
Hi, Elaine,
Firmware Version is V1.0.0.60_1.0.38
I will try the hard reset later today. BTW can I backup my configuration and restore after the hard reset without re-introducing problems?
- ElaineMJun 06, 2016NETGEAR Employee Retired
Yes, you may backup and restore.
Hi ElaineM,
Did a hard reset, reimported the backup and have the original results. Connects tp ipv6 for a short while then ipv6 times out.
