frankc1
Jun 05, 2016Aspirant
wndr4500v2 dropping comcast connection
i have motorola sb6141 cable modem. when pc is directly connected to the cable modem comcast functions well. when i connect to the internet thru my wndr4500v2 router with ipv6 set to WAN/dhcp LAN//...
- Jun 10, 2016
Hi ElaineM,
I have found a solution to this problem. My firewall (Bitdefender) has a default setting to deny incoming ICMP v6 messages. Setting this to allow made the problem vanish.
What I do not understand is why direct connecting the PC to the cable modem worked OK as Bitdefender was still in the loop. Magic I guess.
I believe allowing ICMP messages poses a security risk which seems to be an IPV6 risk. Do you have a comment on this?
Thanks again :-)
ElaineM
Jun 07, 2016NETGEAR Employee Retired
One of our support team will follow-up with you for further diagnosis.
They'll be contacting you separately.
frankc1
Jun 10, 2016Aspirant
Hi ElaineM,
Thanks again :-)
- ElaineMJun 13, 2016NETGEAR Employee Retired
Perhaps, it's due to the firewall.
You can't have 2 firewalls running or you'll have problems.
Router has a firewall and you also have the bit defender. That's why when you bypass the router, it's working fine.
