Barry_Colson's avatar
Barry_Colson
WNDR4500v2 firmware update failed
Installed update and waited for counter to stop.  Could not get a connection.  Saw light on router blinking, turned off router, waited 30 seconds then turned router back on.  Tried to connect to inte...
  • michaelkenward's avatar
    michaelkenward
    Jul 28, 2018
    Sound advice from wcalifas831. Here is Netgear's take on it.
    How to upload firmware to a NETGEAR router using TFTP | Answer | NETGEAR Support
    That is a bit out of date in that it does not tell you that Windows has a TFTP function built in, you just have to enable it.
    • Control Panel
    • Programs and Features
    • Turn Windows features on or off
    • TFTP client - enable
    That's probably easier than retrieving software from a website.
    TFTP is a "command line" utility. In Windows it runs from a Command Prompt window. Get there with Winkey + R and enter cmd.
    To write the firmware to the device you need to type in:
    TFTP -i 192.168.1.1 put {firmware}
    where {firmware} is the name of the firmware file you retrieved.
    Put the firmware in a directory you can get at, and run TFTP from there.
