GeneralPardon
Jan 06, 2022Aspirant
WNDR4500V2 no access
Hi, Bought this second hand router. Purpose was to strengthen my signal in my attic. I have a Ziggo connection (i'm Dutch) to my modem (Technicolor) downstairs. 1 LAN cable connected (amongst o...
GeneralPardon
Thanks for replying!
Nope..
I must have factory reset it at least 10 times by now. (just to be sure, did it again after your message)
Connected, unconnected, WiFi only, LAN to laptop. All did not work: No access to router settings.
Jan 06, 2022Guru - Experienced User
what are all the leds on the router doing? (color/blinking/etc)
- GeneralPardonJan 06, 2022Aspirant
Nothing blinking...
Power: green
Internet: Yellow (or off when not connected)
2.4 ghz: Green
5 ghz: Blue
lan 1: Green
- plemansJan 06, 2022Guru - Experienced User
so after a full reset, with a laptop connect but not the primary router, you still don't get a default gateway when you run a command prompt ipconfig?
No. Nothing with LAN cable and wifi off
Lan disconnected and wifi on default gateway is 192.168.1.1...
