Tech_Newbie's avatar
Tech_Newbie
Wndr4500v2 no internet connection
Ever since I turned my WiFi router off and on, the WiFi and internet haven’t been working. My pc prompted me to log in using admin credentials, which I did, and took me to the net gear genie page. I c...
  • wcalifas's avatar
    Oct 14, 2020
    If you have cable internet you'll have to restart the modem again also. First restart the modem and let it reboot and let it connectt to the internet. Then connect the wndr4500 to the modem and run the setup again. See if that helps out because if you have cable internet the modem marries the router so once you reboot your router you'll have to reboot the modem also first. Let us know what happens
