Tech_Newbie
Oct 14, 2020Aspirant
Wndr4500v2 no internet connection
Ever since I turned my WiFi router off and on, the WiFi and internet haven’t been working. My pc prompted me to log in using admin credentials, which I did, and took me to the net gear genie page. I c...
- Oct 14, 2020
If you have cable internet you'll have to restart the modem again also. First restart the modem and let it reboot and let it connectt to the internet. Then connect the wndr4500 to the modem and run the setup again. See if that helps out because if you have cable internet the modem marries the router so once you reboot your router you'll have to reboot the modem also first. Let us know what happens
wcalifas
Oct 14, 2020Prodigy
Just restart your desktop computer and make sure its connected to the router on one of the four ethernet ports (LAN) of your wndr4500.
Tech_Newbie
Oct 15, 2020Aspirant
wcalifas I just waited for a while and it eventually connected to the internet. Thank you so much for your help!!!!!!! You're a life saver :smileyvery-happy:
