User2020NJ
Sep 26, 2020Follower
WNDR4500v3 Firmware version v1.0.0.60_Beta
Just received an email from NETGEAR indicating that there was a firmware upgrade v1.0.0.60. I've followed the instructions to the letter yet, when I try to upload it returns "Please assign the corre...
antinode
Sep 26, 2020Guru
> I've followed the instructions to the letter [...]
Sure you did. _Which_ "the instructions"? What, exactly, did you
do?
> [...] when I try to upload it [...]
"it"? The zip archive itself (wrong), or the firmware image file
(".img") which you extracted from the zip archive (right), or what?
> Afterwards I did open the zip file and indeed found that it contained
> an image file [...]
"Afterwards" is too late. "open" how, exactly?
> [...] Where is the file? [...]
It's in the zip archive. You need to extract it from the zip
archive. If you're running some version of Windows, then right-click on
the zip archive file (in File Explorer), and select "Extract all..." to
extract the files in the zip archive.
> [...] and a link to the site [...]
That's not a link; it's the whole document.
