cjbryson's avatar
cjbryson
Follower
Nov 09, 2017
WNDR4500v3 N900 can't access settings while in bridge mode
I am attempting to use my router to access internet through a third party wireless network. When I activate bridge mode and provide the necessary (and correct) network information (SSID, security, an...
  • JamesGL's avatar
    Nov 23, 2017
    Hi cjbryson,
    You have to access it via the IP address that you have set on the router when configuring to bridge mode. If you have set a static IP, use that IP address. If dynamic, check with the main routers attached devices for the IP address of the bridge.
